pianotuna wrote:
The camco male plugs seem to be ok--but their female plugs are weak at best.
I've found that the only female receptacles that hold up at all, are the hard "bakelite" kind. I've had to cut the molded female off RV extensions off, and put a box with receptacle on it. I think the whole thing is better: the contacts, the heat-resistant insulator, the clamping connections for the wires.
Got a 50 ==> 30 adapter that I'm going to have to put the box/outlet onto. I like to solder the the stripped strands for a more solid fit when the clamp tightens down.
Hopefully I can give the 830 to somebody who's stuck in a campground. Or, send'em to Walmart for a CAMCO.
And, yes, Roy, always use a Dogbone. Never a Puck!
