LarryJM wrote:
While a tad more $$$ PI makes a decent 30A replacement plug CLICKY
If you don't need a weatherproof one then the $5 hard plastic one from Lowe's works for me albiet not the highest quality it will get the job done. I use that since my plugs go into a weatherproof box, are always off the ground and need to be as small as possible to fit inside the weatherproof outlet box cover.
Larry
Larry I kind of like the Camco and "think" its better. However I have used both and believe that the Camco is easier to put on and fastens easier. Just my opinion though. Another point is that they both go bad over time and if your luck is bad and you get a bad outlet it goes faster.
