stevekk's avatar
stevekk
Poor TV
Well... here we are sitting in a Walmart Parking lot.
I have the Jensen 12 vdc TV on and the 12 vdc Booster on.
The standard bat wing crank up Antenna.
I have the TV Antenna pointed directly towards a mountain I can see in the distance.
I can see the antennas and other misc. equipment on the peak of the Mountain. I can see..Clear line of sight and Clear as a bell... no trees.
No obstructions.
Pretty close, that I can Count the equipment on the hill.
Yet some of the channels still freeze up.
Whats going on?
I would say it sure is a Rinky Dink TV System!
Any ideas?
The antenna sits at an angle, installed on the sloping portion of the roof.
Should it be flat?
Would it help?
  • Not sure where you are sitting, but if your near Portland the antennas are on different spots on the hill. You probably need to rotate the antenna a bit. I know inEast county when I actually used OTA that was a big problem. Add to the fact that many OTA antenna systems built into RV's today are just simply put, junk. Its not hard to figure out why your reception is so poor. Add the cheap TV into the mix and your lucky to get anything.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
