- haydoracinExplorer
rbp111 wrote:
Why would the satellite be useless? If there is one satellite to catch all the channels, wouldn't it be more effective. In other words, the current portable satellite dishes would then be able to get HD channels on KA, where as in todays market they cannot because there are two ways to broadcast, ie KA and KU. Just wondering.
Inquiring minds would like to know ? ? - rbp111ExplorerWhy would the satellite be useless? If there is one satellite to catch all the channels, wouldn't it be more effective. In other words, the current portable satellite dishes would then be able to get HD channels on KA, where as in todays market they cannot because there are two ways to broadcast, ie KA and KU. Just wondering.
- TyroneandGladysExplorer
mikestock wrote:
Keep in mind, whatever you chose, it will be useless by no later than 2019 when "experts" speculate that DirecTV will no longer broadcast SD.
Solid Signal Forum
Thanks for that info.
This I have found out is a big reason for going with the King Quest since you can get a UC 1000 controller that will allow the King Quest to receive Dish HD - mikestockExplorerKeep in mind, whatever you chose, it will be useless by no later than 2019 when "experts" speculate that DirecTV will no longer broadcast SD.
Solid Signal Forum - STBRetiredExplorerHave the King Quest. Works well, no complaints.
- EsoxLuciusExplorerAnother satisfied Winegard G2 Carryout user.
- SparkDrExplorerI used the Carryout for several years & it performs flawlessly. It's recently been retired to a shelf in the garage in favor of a HD setup, but the Carryout has never let me down. Highly recommend it.
- chiefneonExplorerHowdy!
We have been using the G2 now for over a year and has worked out well. The King Quest was not out when we purchased ours. I like the G2 as it is small easy to store. Also once we have a satellite connection I nook the 12 vote power cable and store it away.
"Happy Trails"
Chiefneon - BobboExplorer III
donn0128 wrote:
Neither of those antennas will work if you want Direct HD programming. For HD you want either a roof mounted Winegard Travler or a tri pod mounted oval dish like you use at home.
The OP stipulated standard definition.
OP, this King Flex is what I have and it is wonderful! - 2oldmanExplorer IInever mind
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
