MrWizard's avatar
MrWizard
Moderator
Sep 01, 2017
possibly the Best RV TV antenna ever MFG
Click For Full-Size Image.
the Braund "Skyliner"
crank it up it unfolds, crank it down and it folds up
all the sensitivity of a home directional Yagi
i've mentioned it before, but could not remember the name
i finally tracked it down
Skyliner PDF
i think the short array at the front/right end is for UHF
these thing had great reception
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yes a good Yagi will beat the Batwing.. Not sure yet about that antenna assembly but it resembles one I do know that used to be made not far from where I lived.
    IF you are parked for LONG times, a mast (Such as a Sunsetter flag pole) with a good size residential Yagi.. Well.. I've seen stations over 100 miles away on VHF low band. But that was with a 100' Mast (Tower) at my parent's house.. Even though the house was in the "No Coverage" zone (South of Union City MI on Francisco RD) we got TV from Detroit (over 100 miles Lansing/Jackson, Kalamazoo/Battle Creek/Grand Rapids and South Bend, IN.
  • Both my Airstreams had one. A 66 and 72. That thing could get like 3-4 channels....oh wait.
  • Chris is right, they work great, just don't leave it out in an ice storm, IF you plan on moving
  • GordonThree wrote:
    Looks like a fair weather antenna? Can't see it folding or unfolding too many times in winter climates.
    while it usually didn't matter, I do remember watching a friend up on his Airstream after a freezing rain storm. The rest of us had thought ahead :)
  • Looks like a fair weather antenna? Can't see it folding or unfolding too many times in winter climates.
  • The skyliner works just like a Batwing
    Had a crank inside the RV
    Raise it up then turn it and point in direction of broadcast tower
    Just remember to bring it down before leaving camp
    Late friend of mine had one mounted on a King's Highway class A
    I think Airstream used them also
  • I had 1 of these mounted on a tripod that worked well.
    http://www.ebay.com/itm/Amplified-HD-Digital-Outdoor-HDTV-Yagi-Antenna-with-Motor-Rotor-WA2608-/272806814464?epid=926330017&hash=item3f848da300:g:m84AAOSw2xRYeTQL
    However, it got knocked over once and knocked around in the RV and an element broke off and another one got bent. Still worked well but really was not conducive for an RV.
    So I just got one of these:
    and it pulls in well, is mounted on a tripod, is compact and stores easily.
    http://www.ebay.com/itm/HD-8000-360-Degree-HDTV-Digital-Amplified-Outdoor-TV-HD-Antenna-VHF-UHF-120Mile/182594054244?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
  • Ivylog's avatar
    Ivylog
    Explorer III
    I use much the same when Snowbirding BUT I have to manually fold it up. It's mounted on my ladder so easy enough to point and unfold when needed. Gets good reception without a booster/amp. Yes, the short stubs are for UHF and longer for FM and UHF.
    OH YES, and it's HD but then rabbitt ears are also.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
