Bill_Satellite
Jan 10, 2018Explorer II
No, it's the cable connection that will not work with satellite. I assume you only have the 1 cable connection outside the coach. If you also have an outside connection (or 2) that go into the coach, these are the ones you must use and each input would need to have their own dedicated coax coming from the G2+, one from the Main connection and one from the Aux connection. You would need 2 receivers in the coach or you would have to wire the output of one receiver to feed both TV's but it does not sound like it's currently setup for that.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
