Keith Haw wrote:
You really don't need a pure sine wave inverter, unless you just want one. I run my LED TV and Dish receiver on a cheap truck stop 400w modified sine wave one and they work just fine. As for the laptop the same holds true. I've never had any problems charging it on a regular inverter.
The list of things that will not run properly on a PURE SINE WAVE inverter:
Anything needing more starting power than the inverter can provide
End list.
A partial list of things that may not operate properly on a MSW inverter
Any Radio including TELEVISIONS, Sat Receivers and epically AM radios.
LED lamps
Clocks
Any device using a digital timer
Electric Blankets
and much, much more
Note the inclusion of TELEVISIONS in that list.
He needs a True Sine Wave
There are a few in the 300 watt class on the market, I can not make a personal recommendation but I think one called Samulex (if I've not mangled the spelling) has been recommended by others in the past.
GOOGLE: 300 watt true sine wave inverter
I got a whole stack of hits, Including E-bay where prices are often lower.
