Larryect
Oct 29, 2015Explorer
If the plug you are using is right next to the meters, you could be seeing a voltage drop on the meters due to the load the inverter is pulling thorough the smallish wires feeding the plug.
You might try running the inverter again and check the battery voltage at the batteries at the same time
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
