- HorsedocExplorer IItry holding the off button in for a few seconds. That is the way you have to turn off the radio on my Canyon Starr
- wa8yxmExplorer III
jvann1 wrote:
On my 2019 Sony, you push in on the volume button. Makes no sense but that is the on and off switch. Hope you enjoy your new coach!
That is a very common on/off for many radios and/or Televisions or rather it was back in the day.. not so popular in these days of REMOTE CONTROL but back when I was the remote either push-push or pull to on push to off was very popular. - ryoungExplorerJust curious. Wonder if the OP ever discovered how to turn off his radio?
ryoung - jvann1ExplorerOn my 2019 Sony, you push in on the volume button. Makes no sense but that is the on and off switch. Hope you enjoy your new coach!
- shastagaryExplorerfrom page 27 of the sony manual
Cautions• Do not install this unit in a car that has no ACC position. The display of the unit does not turn off even after turning the ignition off, and this causes battery drain
poor wording so what does it really mean? - wa8yxmExplorer IIINote on missing Remote.
I used to have a Samsung Galaxy S-5 Smart Phone.
It had an IR-Remote feature that operated every TV, VCR and Radio I came across even my Replay TV DVR's...... Alas they dropped that feature with the S-7.
Universal remotes a dollar at your local store of the dollar fame. - ndrorderExplorerThe off button is on the remote. Missing remote? See dealer or replacement from sony.
- wa8yxmExplorer IIISince the coach is only 2 days old. WARRANTY it.
If you must there is a plug on the back of the rig or some other type of connection (Rig = Radio) but since it is only 2 days old WARRANTY IT. - uncle_tExplorerthe coach is 2 days old.
The radio is built in to the dash so rear wiring not something i choose to do.
of course it goes off when the salesman's switch is used. Fine when it is stored. Actually necessary.
Pull the fuse? no comment.
One would think sony would supply a simple on/off switch Duh!!!!
Was hoping i overlooked something. off to the dealer adding this to the list of small problems always present with these beasts. - pianotunaNomad IIIMy radio is powered from the "house" batteries. I have to use the disconnect switch to remove power from it. This allows it to be used when the engine is not running.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
