DD716TED's avatar
DD716TED
Ransomware... Just in case question
I am always worried about losing my important file / photos to some kind of virus or ransomware.. I am under the impression that even though you keep file / photos in the "Cloud", they will also be impacted by a ransomware program as well as those kept on a external disk drive that does backups automatically.. I know I can get an external HD and copy important files / photos to it and then disconnect it and keep it in a safe location if ever needed.. BUT will this do the same thing.. I have a large external HD connected to my PC that is partitioned into 3 partitions.. one of the partitions is used on a scheduled basis for backups but the other 2 are not yet used..If I copy important files / photos to one of these unused partitions and nothing writes to it unless I put it there, would the data placed there be safe from a ransomware program?
  • I have a backup system called WD Smartware that wirelessly backs up my computer. Is it vulnerable to RW?
  • Thanks for all the quick and informative responses.. No sooner that I hit send to post this question, I discovered that I had 3 portable USB hard Drives (30GB, 60GB and 12 GB) that I had totally forgotten about under my workbench. They were used as HD clones for laptops that I had in the past. I will reformat and use one for storing my important files and then put it in a secure area..Thanks again.. This entire RV forum and the contributing members are worth their weight in Gold to me..
  • to answer the OP.. NO..not safe
    if the drive is connected to the PC when the ransomware hits
    it WILL find it an encrypt it, just the same as the stuff on the PC internal drive
    to PC and the ransomware, its ALL one system, anything the PC can access, the RW can get to
    it must be disconnected to be safe
    and IF you ever get hit with the RW it must be removed, aka PC cleaned, before you attempt restore
    or it will lock up / encrypt the external back up drive
  • Crypto ransomware is sophisticated enough to search all drives you have write access. That includes cloud, such as Dropbox, and network attached drives.
    One thing I do is not auto load services such as Dropbox on boot. You still have access to your local Dropbox files, just not allowing it to "auto" sync to stored files in the cloud until I need them. Or, in this case, no suspicious file activity detected. However, if the local Dropbox files did get encrypted by malware, you still have them in tact on their servers.
    Dropbox also uses file versioning, so you "may" be able to restore malware encrypted files to an earlier un-encrypted version. Though have not explored the viability of such as of yet.
    Setting the partitions to read only should protect your files so long as you are not using an admin account while connected to the Net. Also, if unknown vulnerabilities don't exist. Otherwise, pretty much game over. Which is the mistake most make while connected to the Net. Using an Admin account allowing too many privileges for hackers. Instead, create a separate Net user account(s) with limited write privileges. With no access to backup drives.
  • Johno02 wrote:
    Use a 64Gb usb thumb drive, to store and backup your important stuff, I carry mine on my keychain.
    You carry your important stuff on your keychain? :)
  • Use a 64Gb usb thumb drive, to store and backup your important stuff, and just unplug it when not needed. Lots safer than the "cloud", and no internet access needed. Use more than one if necessary, I think you can get them up to 128G now. I carry mine on my keychain.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
