jake2250 wrote:
Dutch_12078 wrote:
Bill.Satellite wrote:
I think he means the Wingman now points 90 degrees off so you do not use the inside pointer as reference but rather 90 degrees off the pointer. With the Razar Air, the pointer will be the front of the Razar Air. Reception front or rear should be the same.
Exactly! :C Hmmm, I'll look at adding a second Wingman to my Sensar pointing the opposite direction from the first to get the same bi-directional performance as the Rayzar. :B
Dutch,,you really sparked my interest in doing a second wingman,,,How would you secure it?? Would the push pins be long enough? And I wonder if it would be more efficient?
First, it would be the Razar AIR and not the Razar and second, you can't add a second Wingman. I know it was typed in humor but it raised some interest.
