jake2250 wrote:
Dutch_12078 wrote:
Bill.Satellite wrote:
I think he means the Wingman now points 90 degrees off so you do not use the inside pointer as reference but rather 90 degrees off the pointer. With the Razar Air, the pointer will be the front of the Razar Air. Reception front or rear should be the same.
Exactly! :C Hmmm, I'll look at adding a second Wingman to my Sensar pointing the opposite direction from the first to get the same bi-directional performance as the Rayzar. :B
Dutch,,you really sparked my interest in doing a second wingman,,,How would you secure it?? Would the push pins be long enough? And I wonder if it would be more efficient?
As Bill said, I was joking, but a second Wingman couldn't be attached the same way the first one is, so I'd look at maybe cutting the second Wingman element set off the mounting plate, and then attaching it to the backside of the first Wingman mount with a fabricated aluminum bracket and pop-rivets. The result should pretty much equal the "front" Wingman results for stations that are in the narrow area directly behind the Sensar. Of course clearance issues when the antenna is lowered would need to be considered before attempting the mod.
