Dutch_12078 wrote:
Bill.Satellite wrote:
I think he means the Wingman now points 90 degrees off so you do not use the inside pointer as reference but rather 90 degrees off the pointer. With the Razar Air, the pointer will be the front of the Razar Air. Reception front or rear should be the same.
Exactly! :C Hmmm, I'll look at adding a second Wingman to my Sensar pointing the opposite direction from the first to get the same bi-directional performance as the Rayzar. :B
I recently opened up my Batwing and here's a photo of its guts:
The way the antenna element is shaped would definitely make it directional for UHF, so adding a Wingman to the back side would not do much.
Can someone tell me how to post a spreadsheet or make the information in a spreadsheet look like something?
Bill, you can use the Snipping tool to capture a portion of the computer screen and then save it as JPG.
