Bill SatelliteHope this is the last time I have to bug you. If you would look this over and tell me if it is correct or incorrect I would appreciate it.
Beginning at the King Power Injector wall plate which has the coax from the O/A ant. AND the coax from the outside Cable connection connected to the back of it (along with the 2 12V wires). The 3rd connector has nothing attached:
1.Run a coax from front of plate connection to the "A" side of A/B switch.
2.Run a coax from "B" side of A/B switch to "To TV" connection on RF Modulator.
3.Run a coax from "TV" connection on A/B switch to three way splitter which feeds all 3 TVs.
From RF Modulator:
Run Y/W/R RCA cables to Direct TV H24 receiver.
From Winegard G2 Plus Carryout:
1.Run coax to Winegard Power Inserter.
2. Run supplied 3 foot cable to H24 receiver.
There is another coax connection on Modulator that is marked "ant in".
does it just remain open?
Perhaps an old guy like myself (77) should not even attempt something like this especially when your knowledge of the subject is somewhere between zero and none, but gotta have something to keep busy with.
Thank You Very much
