I have followed Bill's instructions the best I can and after carefully wiring it all up---cant get it to work.I know I am apparently misunderstanding or doing something wrong. Its bound to be some error between the receiver and the RF modulator or the modulator and A/B switch.
The RF Modulator two coax connections one labeled "ant in" and the other "to TV" along with the YWR RCA cables on the other end which I
attached to the back of the H24 DTY receiver. I know I must connect a coax from one of those two coax connections on the modulator to either the A or the B on the A/B Switch. Which connection on the Modulator do I connect to?
The A/B switch has 3 coax connections: the one in the center is marked TV so I ran a coax from it to the 3 way splitter which distributes to al 3 TVs. The other two are the A and B sides of which i ran one to the modulator as mentioned above. The other connects to coax connector on the face plate of the King Power Injector plate which has the OTA and the Park cable attached to back.
Bill has done super in advising me but as I mentioned I know I am mis understanding something. Anyone have any idea what I am doing wrong?
