Bill.SatelliteOne more time please. I hate to be such a pest but I just can't seem to get this correct or either I have a faulty piece of equipment in the system.
I have the G2+ and the power inserter all set up and connected to the H24 receiver correctly. From back of receiver to the RF Modulator I ran the y/w/r RCA cables. I am assuming I have them properly connected. Color to color on both ends. Then I have a coax ran from the "to TV" connection on the Modulator to the B input on the A/B switch. I have nothing connected to the "ant in" connecter on the modulator.
Now the King wall plate with power injector as I previously mentioned. On the back side of it there are three connections marked "cable TV in", King Jack ant in" and "TV 2 Out". No cable was attached to the TV 2 out. On the front of the plate is one coax connector for TV 1 out. So I removed the Cable TV coax on the back side and ran it to A input on A/B switch as you said. Then ran a coax from the output on the A/B switch back to the connector on back that I had removed the Cable TV from. Next I ran a coax from the TV 1 connector on the front of said plate to the 3 way splitter which supposedly runs to all TVS.
O course I have to turn on the main TV with its own remote control and then use the Direct TV remote for the receiver. Just wondering if I am not doing something correct with the remotes to get to the menu on the receiver. Just says no signal..
Bill I appreciate your time and patience very sincerely. If you see what I am doing wrong please let me know.
