Tom_M1
Jan 22, 2018Explorer
Very interesting project. I tinker with the Raspberry Pi and Arduino devices and appreciate the resources mentioned.
A much simpler approach for folks not inclined to take a DIY approach is a Wink_Hub. This is a device that is a central part of a Home Automation system. I don't know if the Hub will send a power failure alert, but if it does, this is all you would need. There is a vast assortment of Z-Wave and ZigBee sensors and controls available that will interface with the Hub. The Wink Hub retails for $69 but is available online for less than $35.
Here's an article on setting up a Wink Hub:
https://www.howtogeek.com/297291/how-to-set-up-the-wink-hub-and-start-adding-devices/
Another approach is to use one of these:
https://www.amazon.com/KMC-Monitoring-Required-Control-Compatible/dp/B06XRX2GTQ/ref=sr_1_1?ie=UTF8&qid=1516625927&sr=8-1&keywords=Power+Outage+Sensor
I don't know if this would send an alert, but you could periodically check status of the switch.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
