Wrace's avatar
Wrace
Replacement powered wall plate (tv antenna)
This is an old picture of the powered wall plate in my 97 TT. This weekend the slide power switch disintegrated and doesn't look to be repairable.
The antenna on the TT is an antennatek commander amplified bat-wing style.
Is this winegard the proper replacement wall plate? It says it's only supposed to be used with the winegard amplified antenna but I can't see that it makes much difference?
http://www.amazon.com/Winegard-RV-7042-White-Plate-Supply/dp/B000GGL4CG/ref=sr_1_1?ie=UTF8&qid=1393202045&sr=8-1&keywords=Winegard+RV-7042+White+Wall+Plate+Power+Supply
  • I googled antennatec and found replacement panels on their website. Probably the same as Winegard, but you might call their tech support listed.
  • Yes, the Wingard power injector will work with your Antennatek. "Been there, done that."
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
