az99
Feb 01, 2014Explorer
You still need to know the channels. The thing will tell you the strongest channel is 32 for example aiming north. That is great but 32 happens to be 1 local spanish channel and then you let your TV scan for 30 minutes and find out you have 1 worthless channel. In this example all the network channels were to the SW. So either guess again or get out the laptop.
So unless I knew to set the Sensar to channel 17 for example and rotate the antenna until I get the best signal on 17 using the strongest signal was worthless. I still have to go to a site like antenna web and see what channels are available and it shows me what direction they are in.
Like I said the Sensar is worthless unless you know the channels or get lucky and have the channels you want where the scan points you.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
