SCVJeff
Feb 01, 2014Explorer
Absolutely not true. Just because it shows OTA channels by no means makes it "worthless", its still showing you whats where so you can do a scan that gets you some results. It also has an adjustable line amp to help pick up losses in the RV. So I fail to see how its "worthless".
Simply put the Sensar in Scan, find the channels and peak them before you do your scan on the TV That's about as straight forward as it gets. If you insist to know what ATSC channel the Sensar picked up before turning on the TV and looking, that information is available in a 200 page document from the FCC.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
