RLS7201
Feb 01, 2014Explorer II
az99 wrote:
You still need to know the channels. The thing will tell you the strongest channel is 32 for example aiming north. That is great but 32 happens to be 1 local spanish channel and then you let your TV scan for 30 minutes and find out you have 1 worthless channel. In this example all the network channels were to the SW. So either guess again or get out the laptop.
So unless I knew to set the Sensar to channel 17 for example and rotate the antenna until I get the best signal on 17 using the strongest signal was worthless. I still have to go to a site like antenna web and see what channels are available and it shows me what direction they are in.
Like I said the Sensar is worthless unless you know the channels or get lucky and have the channels you want where the scan points you.
You make a good point about finding the strongest channel. Now go back and read the instructions and learn how to force the Sensar Pro to othere channels so you can see where they're at. It's not as worthless as you think. It does require some effort on your part.
Richard
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
