MNtundraRet
Feb 01, 2014Navigator
AZ99:
Judging from your dislike for the Sensor Pro, I would suggest you have other problems from just using the unit.
How far are you from the stations you are trying to get? Are there any mountains, or hills over 500 feet in your path?
Also; it looks like you did your own installation of your current set-up. You most likely have a loose connector, or cable pulling loose from the connector. I would check all connections on the back of the plate, plus those going to the TV. If you go through the switch-box (BOMB) I would run the coaxial directly to the TV to rule out bad connections from the BOMB.
Make sure you disconnect and clean the coaxial connection to the antenna on the roof. This is the most likely place for wrecking incoming signals.
By the way. By complaining about your equipment you are the only one suffering about lack of stations. The rest of us would like to help but we could care less if you refuse to accept help and put the blame where it really belongs.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
