Fredzo
Feb 01, 2014Explorer
WyoTraveler wrote:
Never compared my Jack antenna with the newer crank up but I've had no problems getting reception on my Jack antenna. One big advantage is I don't have to worry about forgetting to crank it down.
With both First Class Licenses, don't you remember that the more meat you have up there to receive the signals (especially VHF), the better off you are? You can match a shorter antenna to the signal, but at the cost of far greater loss than an amp can make up. The noise factor of the amp, the signal loss thru matching devices, etc., more than eat up the signal lost by the shorter, less efficient antenna.
I also have/had both commercial licenses. Don't have the First Phone anymore. Lost it to the General Class. I spent 10 years in Marine Radio/Radar systems and thirty in commercial and aerospace, primarily in antenna design and implementation; everything from ground to space-based to shipboard, and never tried to trim the antenna length when I could help it!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
