MNtundraRet
Feb 03, 2014Navigator
Windsor Dave wrote:
For MNtundraRet:
Mark, Back on 07/03/12 You posted the following:
"I ended up cutting off the last element section close to the outer edge by middle element. There is no wiring between elements to worry about. I refastenned the removed element on top of the casing over large element keeping spacing between small elements similar."
I just installed a Wingman on my pre-2004 Sensar. It significantly improved performance. Am in an RV park north of Phoenix and am reliably getting Tucson stations 120 miles away in addition to all (that I'm aware of) Phoenix stations. Pre Wingman, we were not getting all of the Phoenix stations.
That's the good news. The bad news is that the Wingman prevents complete lowering/stowing of the crank-up Sensar/Wingman assembly.
Do you have an image or sketch of what exactly you did in the way of modifying the Wingman to clear your obstruction? I really like the Wingman and want to continue using it if at all practical.
Thanks,
You would first need to see how much of the Wingman attachment would need to be removed to miss your air-conditioner cover and lower into the correct position on your roof.
The Wingman attachment has two small elements of equal length. I just sawed off the last element by cutting the plastic extension holding the elements close to the second element of equal size. That gave me the few inches necessary to clear the pod and lower the antenna to the roof in the proper location.
You need someone inside to lower the antenna in the correct orientation for storage. Have them stop lowering when the Wingman first touches the obstacle. The Wingman will work with only one of the small elements. If you need more clearance than loosing one element you are out of luck.
I first tried laying the antenna down on the roof by aiming it across the roof in front of the air-conditioner. The problem with doing that is there is no "U" bracket as found on the Winegard antenna base to hold the lowered uprights in place. When driving the RV the antenna could rotate on the roof and loosen the nut inside the gear housing on the roof.
Look at the owner's manual/installation instructions for WINEGARD RV ANTENNA. One of the pages has "ORDERING REPAIR PARTS".One of the pictures shows the Wingman for cutting purposes. I drilled out the piece holding element to the plastic and used a small screw to attach the element to the main antenna cover. Use a sealant to seal the screw-hole. The element could be screwed the plastic base of Wingman instead. You might not need the removed element.
If you could find an alternate way to install a "U" bracket on your roof to keep the down antenna in one place that might work but cause a possible roof leak if not done right.
Cutting the element may not give you your current range. It as a $30 gamble for me if it did not work out right, and the same for you.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
