CoCoDave
Feb 03, 2014Explorer
MNtundraRet wrote:Windsor Dave wrote:
Thanks,
The Wingman attachment has two small elements of equal length. I just sawed off the last element by cutting the plastic extension holding the elements close to the second element of equal size. That gave me the few inches necessary to clear the pod and lower the antenna to the roof in the proper location.
You need someone inside to lower the antenna in the correct orientation for storage. Have them stop lowering when the Wingman first touches the obstacle. The Wingman will work with only one of the small elements. If you need more clearance than loosing one element you are out of luck.
Look at the owner's manual/installation instructions for WINEGARD RV ANTENNA. One of the pages has "ORDERING REPAIR PARTS".One of the pictures shows the Wingman for cutting purposes. I drilled out the piece holding element to the plastic and used a small screw to attach the element to the main antenna cover. Use a sealant to seal the screw-hole. The element could be screwed the plastic base of Wingman instead. You might not need the removed element.
Cutting the element may not give you your current range. It as a $30 gamble for me if it did not work out right, and the same for you.
Thanks, Mark. Is this a rough approximation of what you did?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
