wa8yxm
May 20, 2018Explorer III
How I suggest folks do it
First remove wall plate, LABELE EVERY WIRE or Cable Now see if the Sensar Pro fits without the spacer.> it does. GOOD. it does not see if it fits with teh spacer
now make a small notch to pass the TV one lead off the back of the Sensar Pro
Re-connect label to label (Ant, TV-2 Park cable) and the power leads
Bolt it in place
Hook up TV 1 cable (if used. NOTE if nothign connected to TV 1 you do not need the notch)
Power on and see if it works.. Mine did. Still does.
Bolt it in place
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
