srt20
Jul 06, 2016Explorer
DutchmenSport wrote:
Sorry, should be a little clearer. My terminology is not the best:
Not real sure how an Omni works, but the signal is amplified at the booster. Nothing feeds back to the antenna. It's like a vacuum sweeper. The motor is sucking the air into a hose. The booster is sucking the signal into the wire (boosting it). Any "power" needed (if it uses any) should go through the coax cable, same as a Satallite Dish - like the Tailgater for DishTV.) There is a coax connection at the antenna on your camper. simply unscrew it and use the connector, above, and run longer length to your new antenna.
If you have one of those square (as seen on TV) in-house antennas they advertise, or anything like that, you can plug it into the existing wire that attaches to the Omni and see if you get signals. Really, that might be sufficient to pull in all kinds of channels.
Ok, I understand now. Thanks
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
