rk911
Jul 06, 2016Explorer
srt20 wrote:Bill.Satellite wrote:this is exactly what I am looking for. I just wanted to know the proper way to hook up a residential antenna to my factory camper coax that has a booster.
OTA brodacast or satellite TV broadcast? Assuming you are within 5 miles of the satellite TV broadcast then you are golden. If you are outside that range you could always use your OTA TV antenna to watch the local 5 o'clock news and your satellite to watch everything else.
ok. since you're in a seasonal site just head out to your favorite big box store and get a residential antenna, X-feet of RG-6 antenna coax and a 10'-20' piece of PVC for a mounting mast. mount the antenna to the mast and connect the cable. lash the mast to the rear ladder or wherever convenient and run the cable to the TV through a window, fridge chimney, etc. locate the proper direction to point your antenna, scan for channels and away you go. if you want to add an amplifier there are amps designed for outside use and inside use...take your pick. TV signals are line-of-sight so, depending on the terrain between your antenna and the transmitters, height is your friend (hence the 10'-20' of mast).
if you want to use the factory coax then climb up on the roof. the coax from your RV antenna should terminate at a connector in the roof. run the cable from your residential antenna to that roof connector. or...just disconnect the RV coax from the back of the TV (or selector switch if you have one) and connect the residential antenna to the TV.
if you have more than one TV and you have a selector switch then connecting the residential antenna coax to the TV INPUT of the selector switch would be the way to go.
you can't use the RV amplifier since it is built into the RV antenna. the switch on the wall merely supplies power to the amp.
I hope this helps but gotta tell ya...it seems like a lot of trouble vs. just getting your locals via the satellite.
good luck.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
