Dutch_12078
Jul 06, 2016Explorer III
srt20 wrote:
Thanks. Yes basically I'm just looking to see what to do with the factory antenna boost switch. On or off.
The switch also changes the TV connection between the antenna ("On") and the cable input ("Off"). To use the coax from the existing omni for the new non-amplified antenna without sending 12-volts to it, the best way would be to either pull the fuse for the power inserter, or drop the panel and pull off the '+' wire, and leave the switch on.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
