eskins's avatar
eskins
RV electronics upgrades
Wanted to share some insight on this topic. I bought a used 2003 Itasca suncruiser last year and wanted to get rid of the old picture tube TV's and go with HD/smart tvs. First I called around to a few RV shops to get some estimates. $2-3K just to do hd wiring upgrades and cabinet changes, receiver, did not include TV costs.
Then I went to att/directTV thinking to do it myself. They don't offer HD for their RV types packages and the sales people I dealt with really had no clue. Both DirectTV and the rv shops wanted to replace my winegard minimax antenna that was already on the RV.
I then went to dish, found they have a great pay as you go package, confirmed I didn't need to change out my dish and went with them.
I also purchased the Actiontec hd wireless transmitter/receiver and now, $400 later I have a smartTV, a dish receiver, and an Actiontec wireless device, I have HD satellite service in the main cabin, use the alt out to send sat to the rear TV, and have wireless HD sat services for a TV outside the RV.
This winter I will replace the rear tv and build proper cabinets. Bottom line, don't be afraid to jump in yourself and do your own research. Get in and dig around in your RV. I've achieved what the RV shops wanted at 10% of their costs and didn't have to punch holes in the rv for new cabling and can still use existing cabling for standard RV park cable services .
There's a lot of options out there, I took the simpler one to prove I could do it myself. In hindsight should have bought a dual sat receiver. Easy swap out later.
Next adventure will be to improve wifi.
  • Yes Roy B, HD and SD. Some really good tech points made by the others jumping in here. Yes, Winegard had to reprogram the dish, that took about 20 mins. So far it's fine, I can switch between park cable and sat between the TV's as needed, but my set up as is, wouldn't allow for two different sat channels to be viewed at the same time. I don't see that happening very often, but maybe down the road something to look at.
  • wa8yxm wrote:
    RoyB wrote:
    I guess my question is how are you receiving High Def Satellite HDTV.
    He answered that..> I will expand.
    He switched from Direct to DISHnetwork
    DirecTV uses one bird (101 w) which is in one satellite band Forget if it's Ka or Ku.
    DirecHDTV uses that bird for SD, plus two more HD birds (99/103) which are in the OTHER of those two bands.
    The Dome is a radio antenna. Radio antennas do not care if the signal is analog, Digital, Text, Computer programs, Faximily, We-Fax, Hellscriber,, SSB, DSB w or w/o carrier, CW (morse code) or something else.. Like Television. They only care about the wavelength (Frequency band) thus no dome can get DirecHDTV
    Dish however uses only the one band,, Same one they have always used, Same one DirecTV (no HD) uses.. So by switching to DISH, his dome (if it's new enough and can be reset) gets both SD and HD.
    There is a downside.... On DirecTV, you can have one,two,three, more receivers on one dome.. on Dish,, Since a Dome can only see sats ONE AT A TIME, you can only have one receiver.. or you can use multiple domes.
    You can have multiple receivers with Dishnetwork dome, but they will all be on the same datellite at any one time.
  • I installed a new 32 up front by the door above the window. Made a cabinet where the old tube TV was and I ran my HDMI cable though the A/C vents from front compartment (where the old TV was) to rear bedroom new 32" TV. I have a PC in the cabinet where the old TV was. I download stuff to watch to that PC and that's what we watch. Also I ran "SO" cord in the A/C so I could run the rear TV off the inverter 110 volts that is mounted up front. I use a wireless keyboard with a dongle half way back the RV in the A/C vent on a USB extension so range to the dongle is not an issue. We have movies and TV shows downloaded and can surf the net on both TV's. The only downfall is that only 1 TV at a time can have sound but we never really run both at the same time. If we're watching something up front and go to bed, when I turn off the front TV the sound goes to the rear TV.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I can pickup standard SAT TV with just using one small round dish and it is a pretty great quality TV view but it is not really HIGH DEF TV...
    Before all the fancy stuff came out we would just use a single portable SAT DISH with a two port head and run two RG cables back to the trailer feeding separate SAT RCVRs. Each SAT RCVR fed a different TV set. Worked great and everyone can pick up what ever TV Channel they wanted to view... The only cost was the Portable SAT DISH and the rest of the items was bringing along SAT RCVRs from the house account.
    I suspect your WIRELESS HDMI setup is doing almost the same here...
    This is why those automated TV antennas are so expensive as they have to receive very highly compressed SAT SIGNALS that develops the High Definition TV signal...
    When I read the remarks from the AMAZON page that is selling this unit you can read about all the same type questions everyone was bringing up...
    Roy Ken
    You can see in his post that he switched from DirecTV to Dish. Receiving the HD programming from Dish with an automatic dome antenna is no problem at all.
    The dome antennas are not that expensive ($600 range) but it really does not matter here since he already owns the antenna.
  • I'm now preparing to replace the pitifully small TV in our View. I have a PSW inverter on order and will buy a 32" LED TV. I will build an extra shelf for the inverter, receiver, video switch box, and DVR.
  • RoyB's avatar
    RoyB
    Explorer III
    Roy Ken
