- Bill_SatelliteExplorer IIThat's certainly true. I previously used and discarded the WiFi Ranger due to it's ongoing issues and installed a Cradlepoint MBR95. Never had another issue.
- docjExplorer
Bill.Satellite wrote:
Which brings you right back to a Cradlepoint router! Easy Peasy!
To be fair, there are a number of companies that make routers that provide the same services as does Cradlepoint. JefaTech, WiFiRanger, and The Wirie are but a couple of examples. All of these routers can use "WiFi as WAN" and can distribute a wireless internet connection throughout the network of devices in your RV.
However, in the case cited by the OP the RV park has a wired internet connection at each site. Therefore, the connection to the router would be through an Ethernet port rather than by WiFi. Some of the routers I noted would be able to do this; others are purely wifi devices. - 1492Moderator
gbm97 wrote:
The older man that runs the park said he had all the cable & conduit installed because back then everyone was crying for it. Now they all cry for that dang wireless.
So you weren't joking? He actually does have Ethernet connections throughout the park?
He may be smarter than many are giving him credit, as he can setup wireless AP routers versus wireless repeaters? And not suffer the network speed loss associated with using single radio repeaters.
Though using a wireless repeater may result in a loss of 50% or more in network speed, that doesn't necessarily mean that your speed to the Internet will suffer. It depends on your access speed in the first place and the hardware. In fact, I suffer virtually no loss in speed from my Internet connection when using an outdated router flashed with DD-WRT firmware for use as a wireless repeater, as my 4G mobile data speeds are fairly low compared to a cable broadband connection.
However, you'll likely see the biggest drop in Net access speeds using a virtual software WiFi router. - Bill_SatelliteExplorer IIThe park owner can put as many access points as he likes but if the basic backhaul available to the owner is crappy the service will still be crappy. Even if he has fairly good access, connecting a couple of hundred users would cripple most connections. To get good service you must pay big bucks and RVers are not going to pay what it would cost to provide this service.
- hawkeye-08Explorer IIIIt would not take that park owner much to create a nice wireless setup, simple enough to add some access points at various locations around the park since he has the wires already run.. I have a couple of Linksys WRT54G routers that I am going to add to my rv goodies along with some cables so I can play with them while vacationing... happy days
- Bill_SatelliteExplorer IIWhich brings you right back to a Cradlepoint router! Easy Peasy!
- wa8yxmExplorer IIIA router might work, or you might do be able to set up an Ad-Hock bridge between her laptop and your laptop.. But you are going to need someone who knows a whole lot more about it than me to pull that off.
- Bill_SatelliteExplorer IIWe never are happy, are we!?
- my440NomadThanks for your great info.
We ended up taking the site on Thursday staying until last night.
Looking at the price of modem & cable and the total uncertainty on what to do I just said frig it & went without internet. Girlfriend however managed to snap up the 1 cable for herself...mostly.
It was a Cat5 cable coming from the pole that the other services are on. It was fast enough speed.
Thanks
Have a great summer...stay safe! - kmbeltExplorerwhat rv park is this so we can better understand what is available.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
