jaycocamprs wrote:
I run a old WRT54G Linksys with DD-WRT as a client bridge to access campground WiFi. It feeds a Netgear R6020 router that all our devices connect with. Through put is better with the client bridge setup than having the Linksys as a repeater. Campground network only sees 1 device, and we are behind a hardware firewall. Helps with signal strength, but bandwidth is still an issue.
Care to explain the set up better with this somewhat tech savvy reader?
I have a WRT54G with DD-WRT that is not doing a thing right now.
How do you connect it to campground wifi? How is your net gear connected to the DD-WRT? Do you have to do anything special so that your devices are not visible through the firewall?
