joraz's avatar
joraz
Sat Dish
I bought another RV (76 GMC). Always wanted one. it came with an in-motion satellite dish and receiver. We don't use satellite so I'd like to sell it cheap if it is not obsolete. Is there a market for one of these? It's a Winehard Model RT800T (white dome). It is also sold as RTT-80W. Thanks.
jor
  • I believe a 2010 or newer unit should still work with Dish as well but just to repeat what I mentioned above, it WILL work with DirecTV.
  • do you know when the antenna was purchased/installed?
    Sometime after 2010 as the owner's manual is dated 2010.
    jor
  • RT8000T is the retail number and the RTT-80 is the number used by the OEM's. Same product just a different number.
    This is clearly not a 1976 OEM product so do you know when the antenna was purchased/installed?
    It's likely that this antenna will work just fine with Dish or DirecTV but it ABSOULUTELY will work with DirecTV now and well into the future.
  • Thanks. Sounds like it's not worth messing with. I think I'll just throw it. More room for solar panels.
    jor
  • Odds are it will not work with DISH but should work with DirecTV for a while as long as it's paired with an older DirecTV receiver. Dish recently changed their signal coding and that made a lot of KVH, Kingdome, and Winegard antennas produced before 2012 unable to lock on to their satellites.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
