IBcarguy's avatar
IBcarguy
Satelite wiring in FW dead
I have a new Jayco FW and my Winegard Satellite dish doesn't work when I hook it up to the outside cable connection. If I run the cable through the door and hook it up to the Direct TV box, it searches for a signal, locks in and works fine. Presto...300+ stations. Hook it up the right way and nothing...dead.
I have it back to the dealer and they can't seem to find the problem. They've had it several weeks doing several warranty repairs but haven't fixed the TV problem and seem lost about solving the problem. I'm sure it's a bad connection somewhere or a bad spot in the cable....but where? There's been talk about maybe being forced to run a new cable, but I'm not very keen about tearing this trailer apart to run a new cable. I'm thinking it might be better to run new cable on the bottom side of the trailer along the framework then up through the floor somewhere then to rip apart interior paneling. Any one have any thoughts about this?
  • Check the connections outside my last Jayco had two connections, satellite & cable, next to each other, make sure your on the right connector.
  • You probably have the wrong end of a wire. If the outside connection is for cable, then it is set up for park cable, not a dedicated satellite connection. If you connect your satellite, and do not get a signal at you receiver, either it is the wrong wire, or the connectors are bad. a little continuity checking will find your problem.
    r u sure the outside connection is for satellite and not a park's cable tv system?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
