hermy's avatar
hermy
Satellite tv advice
I am trying to become literate in the satellite tv arena because I would like to buy one. I need advice. Here is my situation. We travel in a fifth wheel which has a standard bat wing antennae now but is wired for satellite. We live in Montana but generally travel in Az, Ca, Tx and are planning a trip to Alaska in about 2 years. We enjoy HD but don't need it. I would prefer some sort of portable dish rather than a fixed set up because I would like to use it at my summer cabin as well. We are not huge sports fans. So my questions are: Which company would best suit us- Dish or Direct? Would the Tailgator be my best option for the dish? Will any of it work in Canada and Alaska? I thank you in advance for any advice you can share.
  • We didn't have a LOT of success in picking up satellite (Direct TV) while traveling in Alaska since the birds are so low in the sky that mountains don't have to be that close to block the signal. I have a total of about $50.00 invested in my entire RVing package which includes a mount (made from PVC pipe) and a used dish ($10.00 purchased from an installer) and the satellite signal finder from Radio Shack. The system works well and is easy to set up (takes about 10 minutes total). Not sure just how much better Dish network might be up there, for the same reasons. I actually have BOTH services (Direct on one home and Dish on another) and don't really have a preference for one over the other but it seems like Direct is easier to set up in the campground (guessing as I've never used DISH for that purpose). The have about the same services but different channels so you might do well to sign on to both web sites and go over the SPECIFIC programing you are interested in to be sure they have it. I've found more variety with Direct but if you want specific channels make sure the service you choose actually HAS that particular one.
    Good luck / Skip
  • There are a lot of places that will sell you a package, ie everything you need to get,setup. IMHO buy an oval dish and tripod from a reputable dealer and plan on HD. Heck go for a DVR too. When it is all setup at home, then simply duplicate that for your RV and cabin. Newer Direct equipment use SWM technology. That is a single wire that carries the signal for two receivers. It does requie a power supply to provide power for the LNB. I simply went with a bit older technology and run 4 wires from the antenna to the two places in my trailer. Works fine for us and saves a few dollars. I guess some day ill have to go SWM, but not right now.
    A DVR will allow you to record hours of programming without the hassle of commercials. That isrobably 85% of our TV watching so for us it is great.
    If you go direct be careful on equipment choices. Some of the newest technology is great for home, but can bedifficuly to setup on multiple TV's in a trailer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
