rk911
Apr 26, 2018Explorer
Bill.Satellite wrote:
Do you like TV? Is it something you plan to watch daily and for more than an hour or 2 per day? Did you want to watch TV even if it's raining? If you said yes to any of these then $300 is not going to do it! Unfortunately, the answer is the Winegard Trav'ler and you are going to need to spend upward of $2000. It's worth it, however!
and along those lines...do you want HD or will standard def do? do you have more than one TV and if so do you want to be able to watch different programs on each set simultaneously? do you want/need a DVR?
unless you're going to park your RV in one spot permanently IMO DISH IS the better choice as they are much easier to deal with when you move to a new location and want to get the local channels for that area.
do you want an an automatc antenna...push a button and it fnds and locks onto the satellites or a manual one you have to set up? roof top? ground mounted?
DISH has 3-satelllites with programming spread across all three. some antennas can lock onto all 3 at once while others can lock onto just one at a time. with those antennas if you change to a channel that's on a different sat the dish has to seek and lock onto that bird and that does slow things down a bit. the Winegard Trav'ler locks onto all 3 birds simultaneously. RF Mogul also makes compatible dish antennas for both DISH and DirecTV.
fugure out what you want before making a purchase. good luck.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
