DD716TED's avatar
DD716TED
Should be simple WiFi question, but???
My home Xfinity router outputs both a 2.4 ghz band and a 5 ghz band... I am trying to use an app on my Samsung A7 tablet that strictly requires the 2.4 band. When I look at settings / connections, it only shows the name of the WiFi network in use BUT not whether it is the 2.5 or 5 ghz which both have the same name.. Any ideas on how to determine which one the Tablet is using? Thanks in advance for any help..
  • I just a retired carpenter but what I understand if your tablet does have 5G your not going to get it.
  • If it’s like my router, if they bands are named the same, the router will auto select which one to connect to. What the criteria is I have no clue. On mine I named them Name-2, Name-5. Then when I want to connect I’m presented with a choice.
  • My thought would be to check the router and see what channel the tablet is using, and adjust accordingly.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
