Naio's avatar
Naio
Explorer II
Aug 31, 2019
Should I put my Mobley SIM in another hotspot when parked?
I am lucky enough to have a Mobley on the original plan.
I want to be very careful with the Mobley, since it wouldn't be possible to fix or replace it if it broke.
I am sometimes parked for extended periods of time, with shore power. Should I get a different, used, hotspot and put the Mobley SIM in it, at those times?
If so, something with a larger range would be useful. Other than that I don't think I need any bells and whistles.
I don't know anything about hot spots, so if this is a good idea, I'm wondering if any of you folks can recommend specific models. Or tell me which ones to avoid :-)
  • Those people that put the Mobley SIM in a traditional hotspot quite a while ago are OK. About a year ago, the SIMs that were still in the Mobleys got locked by AT&T.
    There's a way around it, but you can't just take the SIM out of the Mobley now and put it in a hotspot like you could before (unless you've unlocked it).
  • Naio's avatar
    Naio
    Explorer II
    I do already have an AC adapter for the Mobley, which works great. I was just thinking in terms of preserving the life of the Mobley body in case I need it in the futur.
    I appreciate folks letting me know which hotspot they use and how well it works for them!
  • I put my Mobley in a Unite pro 781 over a year ago that I bought off amazon for about a hundred bucks. The Mobley died over a year ago and it’s in the bottom of a drawer. The unite pro or similar models are far superior to the little Mobley. I follow several wireless tech sites and know of no one who has been “ kicked off the plan” for not using the Mobley. As of now there is 0 danger of that.
    While it’s still working replace it with a better modem and keep it just in case, but chances are that won’t happen. I would think moving the sim back and forth would be a hassle and unneeded. Once you have the better modem with antenna connection if needed and many more WiFi devices that can be connected , and a built in battery to take with you wherever you won’t go back.
  • There are many adapters available to use the Mobley outside the vehicle. You can get ones that work off of USB (5v to 12v)or a 120v converted to 12v.
    Just do a search on Amazon or other sites for Mobley power adapter. That way you don't have to remove it.
    If you just want to use another device a NETGEAR 4G LTE Modem works with the sim card found in the Mobley. I have used it without problems.
  • I have had my Mobley SIM in an AT&T Netgear router ever since someone posted that you could. No issues!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,800 PostsLatest Activity: Apr 28, 2025
