Dutch_12078
Nov 04, 2016Explorer III
If just bumping or shaking it a bit changes the signal quality, and you know the external coax is in good shape, then I'd suspect a loose connection internally. You may be able to separate the plastic covers and repair the connections. If not, a replacement head is not terribly expensive, and an easy swap.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
