wa8yxm
Nov 05, 2016Explorer III
There are many factors.. Some have been covered above.
Recently I lost signal completly, I mean ZERO.. Turns out there is a connector under the Clamshell cable cover in the roof. A new cable end or 2, a new barrel and SIGNAL STRENGTH 90.. As the cable fails you can get a make/break situation.
But But I've had that "Works better down" in some strong signal areas too.
The frequencies used are normally in the 800 MHZ and above area as I recall. This means that as little as a few inches can make a big difference if multi-path recption is present (Signal bouncing off say a Overhanging traffic sign).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
