bennefim
Nov 06, 2016Explorer
Temporary coax replacement improved number of channels received, but the signal breakup continues. Contacted winegard and they said movement of the antenna head by wind or other means would cause signal loss. From some of the responses here, that sounds normal.
Does anyone know if the Jack antenna head or the newer batwing has the same problem? I may consider changing it out if it doesn't.
Doug
Doug
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
