Sam_Spade
Nov 07, 2016Explorer
bennefim wrote:
Contacted winegard and they said movement of the antenna head by wind or other means would cause signal loss. From some of the responses here, that sounds normal.
Maybe, maybe not.
It is not normal or a given that antenna movement WILL cause signal loss. It can but only if the signal is weak to begin with.
Going from a strong signal to no signal is NOT normal.
Does your TV have a display that shows the signal strength ?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
