LarryJM
Nov 09, 2016Explorer II
Bill.Satellite wrote:
This can happen when the incoming signal is too strong. Try turning the antenna away from the signal somewhat and see if it improves. I am in Jacksonville, FL now and I get the best signal on the NBC station with the antenna stowed. I could also use the Sensar Pro to turn down the gain a bit but stowing works just fine.
GREAT POST AND ANALYSIS IMO. This is something that folks need to understand and is very different than what was the situation with the old analog signals. You can definitely overdrive a digital signal and cause the same issue as too weak of a signal.
Larry
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
