ktmrfs
Aug 28, 2021Explorer III
goducks10 wrote:
Why does there need to be a certain amount of separation between the outside/inside antenna's?
If objects block the outside signal pickup then wouldn't the roof of the RV block the inside antenna from the outside antenna?
a non metal roof/walls etc. are transparent to the frequencies in question. so you need about 15 ft seperation between inside and outside antenna to avoid feedback. Even an airstream with windows isn't going to provide much isolation. And most objects outside don't block much signal. Thats why a cell phone works in your house.
High water content does block the signal, but few objects have enough water content.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
