JRRNeiklot's avatar
JRRNeiklot
Small inverter or 12 volt tv?
I just bought a Samsung 24 inch tv that I really like. It has the option of playing video straight from a flash drive, an option I really want. I had trouble finding the right size barrel plug - see this thread.
So, my options are run it off my 2000 watt inverter which will suck more juice than I like, use my small 300 watt modified sine wave inverter that I can plug into the 12 volt plug in the rv - just turning this inverter on without a load causes the lights to dim momentarily -, or return this tv and purchase something else. I'm leaning toward just sending it back, but I would like to get a few other opinions on the matter.
Thanks in advance for any advice.
  • I wired my TV that had a 12v power brick to the MH 12v line for some lights. It works fine. I would do the same with your 14v TV. It draws very little current so you could tap in almost anywhere that the 12v voltage stays on. The only question is how low is the voltage that the TV would stop working. The voltage should stay above 12.0v and if plugged in it will be 13.2v or more.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
