jcpainter's avatar
jcpainter
Small wireless laser printer/scanner/copier
I'm looking for a reasonably small wireless laser printer/scanner/copier. I can't seem to find one that meets all the criteria.
Does anyone know of one that meets ALL of the above criteria?
Thanks
  • Gdetrailer wrote:
    HP Laserjet Pro M29W is most likely going to be about the smallest you are going to find that has scanning built in.
    Found HERE
    From what I am reading it does scan in color, but it is only monochrome (B&W) for printing.
    Due to the size, the input paper tray cannot store paper when closed.
    Thank you very much.
  • fj12ryder wrote:
    What are your criteria? Not everyone thinks the same when it comes to size.
    Most combination print/scan/fax all in one units seem be built under the assumption that everyone whats a full sized floor standing office copier.. Many of these units now days are way oversized and will not fit on a desk.. The average multi use printer takes up the space of 4 GC2 batteries (two stacks of two) and that would be on the small side.
    I don't understand why they have grown, but they have..
    HP does have some smaller printer/scanners which is most likely the direction the OP will need to go.
  • HP Laserjet Pro M29W is most likely going to be about the smallest you are going to find that has scanning built in.
    Found HERE
  • What are your criteria? Not everyone thinks the same when it comes to size.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
