- CA_TravelerExplorer III
TenOC wrote:
IrfanViewtoedtoes wrote:
For Web and "sharing with friends", I downsize to 72dpi and no more than 720pixels on the largest side.
Can you do this in a batch? What Software? - toedtoesExplorer III
Gdetrailer wrote:
NRALIFR wrote:
Gdetrailer wrote:
NRALIFR wrote:
You don't need to compress it any more. What you need is software that will reduce the image size (H x W) and quality, which in most cases will not noticeably affect the image for forum posting use. I believe Irfanview will do that, but to be honest I haven't really played with it much so I could be wrong. I have an old image editing program called Image Expert that has a very easy to use interface that allows you to choose four levels of image quality, and change the image size in pixels while maintaining the height to width aspect ratio. Doing that can have a dramatic effect on the file size, and still have an image suitable for emailing or forum posting.
Unfortunately, Image Expert isn't available anymore, but I'm sure there are other programs that willl do the same things.
There is no "magic bullet".
You can't have top quality AND large size and compress it into a smaller file size.
Personally, if the OPs idea is small file sizes to EMAIL then why bother taking the photos at top resolution setting on the camera?
If you have say a 10 megapixel camera, set it to take 5 or 6 mega pixel photos.. You will cut your photo file size in half and for all intents and purposes most folks on the other end of the email will never notice the difference..
You can easily cut the photo resolution (on the camera) down to 2 megapixels and still have plenty of detail to print off a 8x10 photo without noticeable pixelation..
Alternatively, if the OP wants the folks to get supersized photos without going to the hassle of resizing them all then I would recommend simply signing up for a Google email address.. You get 15 GB of FREE GOOGLE DRIVE online storage space and you CAN easily SHARE those photos.
On Google drive you simply setup a SHARED folder, copy your photos to that folder. Then you generate a URL link to that folder.
You then EMAIL THE GOOGLE LINK to the folks you want to share the photos with.
They then can view and download the photos they want.
I didn't say or imply that you could have both large size and top quality. The OP wants to know how to reduce the file size of pictures so they're suitable for emailing, and I told him of a way that works for me.
I don't always know what I'm going to do with the pictures I take, so I typically use the highest quality setting on my camera. It's very easy (for me) to then reduce the size and quality of the pictures I want to email, or post on a trip report in the Truck Camper forum, to get a file size that's easier to email or upload to my image hosting site. I've done this for literally hundreds of pictures I've posted on the forum, and I still have the original high quality/full sized image for my use. I rarely ever bother printing a photo in any of the traditional small format sizes. When I have a picture I want printed, I usually want it BIG, and that's when I'm glad I have the full sized, high quality image to work with.
You apparently like your way, I like mine.
"Bigger" to start with is not "always" better.
Unless you are planning to view the photos 1 foot away from a billboard, anything over 2 mega pixels for general viewing is pretty much a waste.
When you manually "downsize" a photo you ARE throwing away ALL of that extra resolution you started with.
In other words you end up throwing out PIXELS in the process.
In reality you are doing the very same thing as setting the camera to a lower resolution.
There are some actual advantages to letting the camera do the sizing.. One of them is the camera is working with RAW data, this results in LESS ERRORS which results in less pixelization.
Downsizing a very lossy and highly compressed format such as a JPEG results in a lot of errors. If you understood how data compression works you would have an understanding of data errors that get worse when you compress, uncompress then recompress.
Data compression basically compares data, creates a "token" for common data then throws away the common data and inserts the token..
Errors in this process can and do happen and when they do you get pixelization. Editing software while it can resize the photo (IE throw out data) can introduce errors, cheap or free editing software can take good data and trash it.
As I mentioned before, a 2 megapixel photo gives you a 8x10 photo print, 1 mega pixel gives you a 4x6 photo print..
Just how big of a photo do you really want to look at is the question.. A billboard or a 22" computer screen?
If all you're doing is looking at photos on a computer screen, then
yes, larger sized images are a waste. However, locking yourself
to a smaller size by default means you don't have any options for doing anything more with the image. - toedtoesExplorer III
I do it manually one by one normally as I only share the best of my images. I use Photoshop and Lightroom. Lightroom allows you to batch process. However, it's not a free program and unless you want to do more than just resize, it's not worth the cost. - GdetrailerExplorer III
Just how big of a photo do you really want to look at is the question.. A billboard or a 22" computer screen? - NRALIFRExplorer
:):) - TenOCNomad
Can you do this in a batch? What Software? - toedtoesExplorer IIIIt all depends on what you do with your photos and how serious of a hobby photography is.
For most folks, all these new cameras with 10+mp resolutions are way overkill - but folks buy them because "bigger is better".
However, I was told years ago by someone who said always shoot the highest resolution your camera allows - for 99 percent of the time, it's overkill. But for that ONE photo, you'll be glad you did.
I don't print anything less than 10x12. For Web and "sharing with friends", I downsize to 72dpi and no more than 720pixels on the largest side. But, I always keep a full-size print ready version (tiff) and the original raw format. I have never regretted keeping those large files, but I sure have regretted the loss of some of those large files. And being able to give a friend a large framed print of her daughter on a fashion runway was worth the storage of those large files. - 2oldmanExplorer II
richheck wrote:
Paint has been there for years, but does one at a time.
Microsoft Word incorporates a simple Photo resized for quick modifications - richheckExplorerMicrosoft Word incorporates a simple Photo resized for quick modifications, copy, paste then resize.
- Clay_LExplorerI have used Fast Image PowerToy Clone Resizer for years.
It integrates into the right click menu.
Info below is from a download website.
Image Resizer Powertoy Clone is a very handy Windows utility that enables you to resize images very quickly. The program directly integrates itself into Windows’ contextual menu, giving you the fastest access possible to it. Unlike other image resizing programs, with this tool you do not need to locate your images or create lists of them beforehand - just right-click on any number of images and choose the “resize” option to change their dimensions. The good thing is that the resized images are saved to the same location where the original images are, though these are not modified unless you decide to overwrite the original files.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 14, 2025
