time2roll
Mar 13, 2017Nomad
Plays out same as any 17v charger on a 12v battery. Voltage will steadily rise to 17 volts. Your panel is maybe 4 amps so the effect will be slow. So slow you may never get above 13 volts while in use. Monitor the voltage rise closely the first few times. Best to have a controller in storage.
Unless it has a diode, best to disconnect as the sun drops.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
