rexlion
Mar 14, 2017Explorer
MrWizard wrote:
'knock down' is not the right term
PWM means Pulse Width Modulation
the power is pulse on and off hundreds of time a second to maintain a set point voltage aka 14.?
the higher the battery voltage (state of charge) the shorter the on time of the pulse and the longer the OFF time between pulses
thats the simple basic straight forward explanation of the operation
Thanks for that explanation. So if I'm understanding correctly, the PWM may not be pulsing off much (or at all) when the battery voltage (and charge level) is very low. Interesting! I can see now why a direct charge (without controller) wouldn't be appreciably faster.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
