wa8yxm
Apr 09, 2018Explorer III
It should cause no problems at all. Though as someone said, that is about the max for that wire.
The only POSSIBLE issue, and this is why they use heavy wire on solar panels, is VOLTAGE DROP. since, in the unlikely case those panels actually put out the rated power of 360 Watts. at 12 volts you are at 30 amps. which is the rating for 10GA wire in bundles or conduit. OF course you won't be looking at 12 volts. but more likely 13-14.6 (Reduces current) or even higher on the pre-controller side. and you can usually only count on about 1/2 the panel rating.
So you should be good.. Heavier wire might result in a slightly faster charge on the batteries is all.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
